tool:sewing_machines [2019/03/29 05:06] – 00739 | tool:sewing_machines [2024/09/22 20:56] (current) – elizabot | ||
Line 6: | Line 6: | ||
Older machines tend to have more solid metal parts and build, and can sew through tougher materials like denim, leather and multiple layers. | Older machines tend to have more solid metal parts and build, and can sew through tougher materials like denim, leather and multiple layers. | ||
- | **Sewing Machine | + | **Sewing Machine |
- | * Check what kind of needle is in the machine. Different needles are for different fabric. If your needle is dull, crooked or snagging | + | * // **Important note**// Please make sure that you have the needle all the way up before you remove the fabric. If the fabric doesn' |
- | * //It keeps jamming from the bottom// - Check that your bobbin is wound correctly and inserted in the right direction | + | * // **Important note**// Not all feet work on all sewing machines! |
- | * //I'm sewing but all my stitches fall out// - Did you run out of bobbin thread? | + | * //**My stitches are uneven / keep skipping**// |
- | * //Threads are too loose or pulling tight// - Check the tension dials and stitch length. | + | * //**It keeps jamming from the bottom**// - [[tool: |
- | * //I'm sewing but it won't go anywhere// - Check your stitch length and style, are you on a stretch stitch or fancy? | + | * //**I'm sewing but all my stitches fall out**// - Did you run out of bobbin thread? |
+ | * //**Threads are too loose or pulling tight**// - Check that your machine is threaded correctly. | ||
+ | * //**I'm sewing but it won't go anywhere**// - Check your stitch length and style, are you on a stretch stitch or fancy? Are you trying to sew with the presser foot up? | ||
Line 18: | Line 20: | ||
- | * Product Page: http:// | + | * [[http:// |
- | * Manual: | + | * [[http:// |
- | * Quick Reference: | + | * [[http:// |
Line 38: | Line 40: | ||
+ | * Repair receipt with warranty: {{: | ||
- | ===== Kenmore Ultrastitch | + | ===== Kenmore Ultrastitch |
- | {{ :tool:kenmoreus12.jpg? | + | {{ :tool:KenmoreUltrastitch6.jpg? |
Line 63: | Line 66: | ||
^ Value | $ | | ^ Value | $ | | ||
- | ===== Singer 656G ===== | ||
- | * Type: Slant Shank Sewing Machine | ||
- | * Manual: Not found, but possibly hard copy available at the space | ||
- | ^ Status | ||
- | ^ Training | ||
- | ^ Hackable | ||
- | ^ Usage Restrictions | Anyone | ||
- | ^ Owner | VHS | | ||
- | ^ If it Breaks | ||
- | ^ Loan Status | ||
- | ^ Location | ||
- | ^ Value | $ | | ||
- | ^ Champion | ||
+ | ===== Singer Stylist 478 ===== | ||
- | ===== Singer Stylist 478 ===== | ||
- | * see manual | ||
Line 95: | Line 82: | ||
Line 101: | Line 88: | ||
====== VHS Sergers ====== | ====== VHS Sergers ====== | ||
- | ===== Kenmore 3/4 Differential Feed ===== | + | ===== Janome MyLock 234D ===== |
- | {{ :tool:kenmore34serger.jpg? | + | {{ :tool:janomemylock.jpg? |
- | ^ Status | + | |
- | ^ Training | + | ^ Status |
- | ===== Janome MyLock 234D ===== | + | [[http:// |
- | * Manual: http:// | + | ====== VHS Embroidery Machine ====== |
- | {{ : | + | ===== Brother PE 800 ===== |
- | ^ Status | + | {{: |
- | ^ Training | + | |
- | ^ Value | $$ | | + | ^ Value | $$$ | |
+ | There are spare needles and a USB drive inside the purple cover. | ||
+ | ===== Reliable Sewing Machines RELSEW GC0618-1 ===== | ||
+ | The don't mess around & will sew darn near anything industrial machine. It will happily sew leather, canvas, denim, | ||
+ | ^ Usage Restrictions | Anyone with experience | ||
+ | ^ Value | $$$$ | | ||
tool/sewing_machines.1553836019.txt.gz · Last modified: 2019/03/29 05:06 by 00739
