tool:sewing_machines [2019/03/29 04:22] – 00739 | tool:sewing_machines [2024/09/22 20:56] (current) – elizabot | ||
Line 6: | Line 6: | ||
Older machines tend to have more solid metal parts and build, and can sew through tougher materials like denim, leather and multiple layers. | Older machines tend to have more solid metal parts and build, and can sew through tougher materials like denim, leather and multiple layers. | ||
- | Sergers can be set to 3 or 4 thread | + | **Sewing Machine FAQ:** |
+ | * // **Important note**// Please make sure that you have the needle all the way up before you remove the fabric. If the fabric doesn' | ||
+ | * // **Important note**// Not all feet work on all sewing machines! | ||
+ | * //**My stitches are uneven / keep skipping**// | ||
+ | * //**It keeps jamming from the bottom**// - [[tool: | ||
+ | * //**Threads are too loose or pulling tight**// - Check that your machine is threaded correctly. Check the tension dials and stitch length. | ||
Line 13: | Line 20: | ||
- | * Product Page: http:// | + | * [[http:// |
- | * Manual: | + | * [[http:// |
- | * Quick Reference: | + | * [[http:// |
Line 33: | Line 40: | ||
+ | * Repair receipt with warranty: {{: | ||
- | ===== Kenmore Ultrastitch | + | ===== Kenmore Ultrastitch |
- | {{ :tool:kenmoreus12.jpg? | + | {{ :tool:KenmoreUltrastitch6.jpg? |
Line 58: | Line 66: | ||
- | ^ Value | $$ | | + | ^ Value | $ | |
- | ===== Singer | + | |
- | * Type: Slant Shank Sewing Machine | + | ===== Singer |
- | * Manual: Not found, but possibly hard copy available at the space | + | |
- | {{ :tool:singer658g.jpg? | + | {{ :tool:singerstylist478.jpg? |
Line 74: | Line 82: | ||
+ | ====== VHS Sergers ====== | ||
- | ===== Singer Stylist 478 ===== | + | ===== Janome MyLock 234D ===== |
- | * see manual | + | |
- | * see manual | + | {{ :tool:janomemylock.jpg? |
- | {{ :tool:singerstylist478.jpg? | + | |
- | ===== Kenmore 3/4 Differential Feed ===== | + | [[http:// |
- | {{ :tool:kenmore34serger.jpg?direct&400|}} | + | ====== VHS Embroidery Machine ====== |
- | ^ Status | + | |
- | ^ Training | + | ===== Brother PE 800 ===== |
+ | {{:tool:embroidery_machine_brother_pe800.jpg?400|}} | ||
- | ^ Value | $$ | | + | ^ Value | $$$ | |
+ | There are spare needles and a USB drive inside the purple cover. | ||
+ | ===== Reliable Sewing Machines RELSEW GC0618-1 ===== | ||
+ | ^ Usage Restrictions | Anyone with experience on domestic machines | ||
+ | ^ Value | $$$$ | | ||
- | ===== Janome MyLock 234D ===== | + | There is a threading guide on the wall behind the machine. |
- | * Type: Serger | + | |
- | * Manual: http://janome.com/siteassets/support/manuals/ | + | [[https://vanhack.ca/lib/exe/fetch.php? |
- | * Donated by Miststlkr. | + | |
- | {{:tool:janomemylock.jpg?direct&400 |}} | + | Additional info from dbynoe: |
tool/sewing_machines.1553833340.txt.gz · Last modified: 2019/03/29 04:22 by 00739
