tool:sewing_machines [2019/03/29 04:09] – 00739 | tool:sewing_machines [2024/09/22 20:56] (current) – elizabot | ||
====== VHS Sewing Machines ====== | ====== VHS Sewing Machines ====== | ||
- | VHS has the following | + | VHS has a variety of sewing |
+ | Newer machines are more accurate and have more complex functions | ||
+ | Older machines tend to have more solid metal parts and build, and can sew through tougher materials like denim, leather and multiple layers. | ||
+ | **Sewing Machine FAQ:** | ||
+ | * // **Important note**// Please make sure that you have the needle all the way up before you remove the fabric. If the fabric doesn' | ||
+ | * // **Important note**// Not all feet work on all sewing machines! | ||
+ | * //**My stitches are uneven / keep skipping**// | ||
+ | * //**It keeps jamming from the bottom**// - [[tool: | ||
+ | * //**Threads are too loose or pulling tight**// - Check that your machine is threaded correctly. Check the tension dials and stitch length. | ||
- | * Type: Sewing Machine | + | |
- | * Product Page: http:// | + | |
- | * Manual: http:// | + | |
- | * Quick Reference: http:// | + | |
- | * [[http:// | + | |
- | * [[https:// | + | |
- | {{ https:// | ||
- | + | * [[http:// | |
===== Janome 6019 ===== | ===== Janome 6019 ===== | ||
+ | ^ Owner | VHS | | ||
+ | ^ Value | $$ | | ||
- | {{:tool:janome6019.jpg?direct& | + | * [[https:// |
+ | * Repair receipt with warranty: | ||
- | ===== Singer 5805 C ===== | ||
- | * Type: Stitch Sewing Machine | ||
- | * Manual: http:// | ||
- | * [[https:// | ||
- | * Donated by Miststlkr. | ||
- | * {{http:// | ||
- | Maintenance Log - Aug 20th | + | ===== Kenmore Ultrastitch 6 ===== |
- | Cleaned, Oiled and lithium grease on gears. | + | |
- | Checked all Stitches. | + | |
- | ===== Kenmore Ultrastitch 12 ===== | + | {{ : |
+ | ^ Value | $ | | ||
- | ===== Singer 656G ===== | ||
- | * Type: Slant Shank Sewing Machine | ||
- | * Manual: Not found, but possibly hard copy available at the space | ||
===== Singer Stylist 478 ===== | ===== Singer Stylist 478 ===== | ||
- | ===== Kenmore 3/4 Differential Feed ===== | + | ====== VHS Sergers ====== |
===== Janome MyLock 234D ===== | ===== Janome MyLock 234D ===== | ||
- | * Type: Serger | + | |
- | * Manual: http:// | + | {{ :tool: |
- | * Donated by Miststlkr. | + | |
- | {{:tool:janomemylock.jpg?direct&400 |}} | + | ^ Status |
+ | [[http:// | ||
+ | ====== VHS Embroidery Machine ====== | ||
+ | ===== Brother PE 800 ===== | ||
+ | ^ Value | $$$ | | ||
+ | There are spare needles and a USB drive inside the purple cover. | ||
+ | ===== Reliable Sewing Machines RELSEW GC0618-1 ===== | ||
+ | ^ Usage Restrictions | Anyone with experience on domestic machines - watch your fingers! | | ||
+ | ^ Value | $$$$ | | ||
tool/sewing_machines.1553832578.txt.gz · Last modified: 2019/03/29 04:09 by 00739
