tool:industrial_arm
tool:industrial_arm [2024/04/30 04:34] cfmjohntool:industrial_arm [2024/04/30 14:57] (current) cfmjohn
Line 25: Line 25:
 Boot up a terminal emulator which can work with an RS232 tty connection. Boot up a terminal emulator which can work with an RS232 tty connection.
 The settings you'll need to connect to it are: The settings you'll need to connect to it are:
-* Baud rate: 9600 +  * Baud rate: 9600
-* Flow control: none +  * Flow control: none
-* Parity: none +  * Parity: none
-* Data bits: 8+  * Data bits: 8
 On Linux the USB to Serial interface device is probably /dev/ttyUSB0 On Linux the USB to Serial interface device is probably /dev/ttyUSB0
tool/industrial_arm.txt · Last modified: 2024/04/30 14:57 by cfmjohn
