tool:cutting_table
tool:cutting_table [2013/11/21 20:22] – created jarrett | tool:cutting_table [2019/04/04 21:48] (current) – 00739 | ||
====== Overview ====== | ====== Overview ====== | ||
- | owner = Vancouver Hack Space\\ | + | |
- | user certification required = NO\\ | + | The cutting table in the crafting are is a large table with a self-healing surface. The table has cubbies underneath for tool storage, and the table itself opens up to reveal larger storage inside. Be careful, the table lid is very heavy to lift. |
- | hackable = YES\\ | + | |
- | arrived = July 2013\\ | + | ^ Status |
- | doesitwork = WORKING\\ | + | ^ Training |
- | if it breaks = Fix, or post to the list.\\ | + | ^ Hackable |
- | contact | + | ^ Usage Restrictions | Anyone |
- | where = South west corner | + | ^ Owner | VHS | |
- | value = $400 parts + labour\\ | + | ^ If it Breaks |
+ | ^ Arrival Date | July 2013 | | ||
+ | ^ Value | $400 parts + labour | ||
Work area size = Approximately 4' x 8' (1.2m x 2.4m) | Work area size = Approximately 4' x 8' (1.2m x 2.4m) | ||
Line 14: | Line 20: | ||
Only use cutting implements intended for a self-healing cutting mat. In practise, this means **rotary cutters only**! Other cutters, such as box cutters and exacto knives will gouges the surface, causing runs in fine fabrics. | Only use cutting implements intended for a self-healing cutting mat. In practise, this means **rotary cutters only**! Other cutters, such as box cutters and exacto knives will gouges the surface, causing runs in fine fabrics. | ||
+ | If you need to use an exacto knife, we have small cutting boards available under the table. | ||
tool/cutting_table.1385065343.txt.gz · Last modified: 2015/12/12 14:31 (external edit)
