tutorials:custom_springs
tutorials:custom_springs [2017/07/09 06:07] – rsim | tutorials:custom_springs [2017/07/09 06:14] – rsim | ||
You can make custom springs of any size on the lathe with music wire (piano/ | You can make custom springs of any size on the lathe with music wire (piano/ | ||
- | D' | + | [[http:// |
For 0.8mm and up you're looking at piano strings, which are apparently hard to buy in Canada (you have to be a licensed piano tuner!). They can be purchased from AliExpress however, or from most hobby shops as 'music wire' - see the [[: | For 0.8mm and up you're looking at piano strings, which are apparently hard to buy in Canada (you have to be a licensed piano tuner!). They can be purchased from AliExpress however, or from most hobby shops as 'music wire' - see the [[: |
tutorials/custom_springs.txt · Last modified: 2019/04/09 19:22 by 00739
