Next revisionBoth sides next revision
tool [2022/01/28 00:17] miketool [2024/02/20 20:47] tyisi
 ====== Equipment and tools at VHS: ====== ====== Equipment and tools at VHS: ======
Line 43: Line 42:
 | [[tool:vacuum_chamber|Vacuum Chamber]] | [[tutorials:fusion360|Fusion 360]] |  | [[tool:vacuum_chamber|Vacuum Chamber]] | [[tutorials:fusion360|Fusion 360]] |
 | [[tool:acrylic_bender|Acrylic Bender]] |  |  | [[tool:acrylic_bender|Acrylic Bender]] |  |
-| [[tool:injection_molder|Injection Molder]] |  |
 | [[tool:vacuum_investment_casting_machine|Vacuum Investment Casting Machine]] |  | | [[tool:vacuum_investment_casting_machine|Vacuum Investment Casting Machine]] |  |
Line 84: Line 82:
 | [[tool:Infrared IC Heater]] | [[tool:Rigol MSO1074Z]] |  | | [[tool:Infrared IC Heater]] | [[tool:Rigol MSO1074Z]] |  |
 | [[tool:Hakko Omnivise PCB Holder]] |  |  | | [[tool:Hakko Omnivise PCB Holder]] |  |  |
-| [[tool:Essemtec PCB Oven]] | [[tool:Essemtec Pick and Place]] |. [[tool:Essemtec Stencil Screen Printer]] |+| [[tool:Essemtec PCB Oven]] | | |
 +| [[tool:Essemtec Pick and Place]] | | |
 +|.[[tool:Essemtec Stencil Screen Printer]] | | |
Line 93: Line 93:
 ^ Machines ^ Supplies ^ misc ^ ^ Machines ^ Supplies ^ misc ^
 | [[tool:Industrial Arm]] | [[tool:officesupply|Office supplies]] | [[tool:admincabinet|Admin Cabinet]] | | [[tool:Industrial Arm]] | [[tool:officesupply|Office supplies]] | [[tool:admincabinet|Admin Cabinet]] |
-| [[tool:Mini-fridge]] | [[tool:labelingsupplies|Brother QL-570 Label Printer]] | [[tool:arcademachine|Arcade Machine]] |+| [[tool:Mini-fridge]] | [[tool:Keggerator]] | [[tool:labelingsupplies|Brother QL-570 Label Printer]] | [[tool:arcademachine|Arcade Machine]] |
 | [[tool:Chromecast|Chromecast TV and Speakers]] | [[tool:labelingsupplies#box of label strips|Labeling supplies]] | [[hacks:led_wall|LED Wall]] | | [[tool:Chromecast|Chromecast TV and Speakers]] | [[tool:labelingsupplies#box of label strips|Labeling supplies]] | [[hacks:led_wall|LED Wall]] |
 | [[tool:ultrasonic_cleaner|Ultrasonic Cleaner]] | [[tool:cleaning_supplies|Cleaning supplies]] | [[tool:social_buttons|VHS Social Buttons]] | | [[tool:ultrasonic_cleaner|Ultrasonic Cleaner]] | [[tool:cleaning_supplies|Cleaning supplies]] | [[tool:social_buttons|VHS Social Buttons]] |
Line 116: Line 116:
 | [[tool:refrigerator]] | Beer? |  | [[tool:refrigerator]] | Beer? |
 | [[tool:coffee_machine|Coffee Machine]] | Cups | | [[tool:coffee_machine|Coffee Machine]] | Cups |
-| [[tool:hot plate]] | +| [[tool:hot plate]] | [[tool:Brewing Equipment]] |
 | [[tool:Convection Oven]] |  | [[tool:Convection Oven]] |
Line 127: Line 127:
 ^ Machines ^ Supplies ^  ^ Machines ^ Supplies ^
 | [[tool:RedSail CM1080 Laser Cutter]] | [[area:material_storage|Laser cutter material storage]] |  | [[tool:RedSail CM1080 Laser Cutter]] | [[area:material_storage|Laser cutter material storage]] |
-| [[tool:laserfilter|Laser cutter filtration system]] | [[tool:laser_cutter:materials|Approved Laser Cutter Materials]] |+| [[tool:laserfilter|Laser cutter filtration system]] | [[tool:laser_cutter:settings|Approved Laser Cutter Materials]] |
-====== Metal Work ======+====== CNC Area======
-See: [[area:metal_shop|Metal Shop]], [[area:welding|Welding Zone]]+See: [[area:metal_shop|Machine Shop]]
 ^ Stationary Machines ^ Portable Tools ^ Tools ^ Supplies ^ ^ Stationary Machines ^ Portable Tools ^ Tools ^ Supplies ^
-| [[tool:Sherline CNC Mill]] | [[tool:Welder|Millermatic 211 MIG Welder]] | Hand Tools | Safety Equipment | +| [[tool:Sherline CNC Mill|Sherline]] | Shopvac (Shared with Machine Shop) | Hand Tools | Safety Equipment |
-| [[tool:Grizzly X3 4-Axis CNC Mill]] | [[tool:PowerTIG250EX|PowerTIG 250EX Welder]] | [[tool:Norseman Drill Bit Set]] | Flux | +| [[tool:Grizzly X3 4-Axis CNC Mill|CNC Mill "Gage"]] |  | CNC Tool Library (WIP) | Flux |
-| [[tool:manual_lathe|Metal Lathe]] | [[tool:Bosch 4.5" Angle Grinder]] |  | [[tool:fasteners|Nuts, Bolts, Screws, Washers...]] | +| CNC Mill "Jaxon" |  |  | [[tool:fasteners|Nuts, Bolts, Screws, Washers...]]
-| [[tool:6040 CNC Mill]] | [[tool:Cut-Off Saw]] |  | Donated metal |+| [[tool:6040 CNC Mill|6040 CNC Mill "Laratron"]] |
 +| [[tool:Drill Press]] |
 +====== Machine Shop ======
 +^ Stationary Machines ^ Portable Tools ^ Tools ^ Supplies ^
 +| [[tool:Green Manual Mill]] | [[tool:Welder|Millermatic 211 MIG Welder]] | Hand Tools | Safety Equipment |
 +| [[tool:manual_lathe|Metal Lathe]] | [[tool:PowerTIG250EX|PowerTIG 250EX Welder]] | [[tool:Norseman Drill Bit Set]] | [[tool:fasteners|Nuts, Bolts, Screws, Washers...]] |
 +| [[tool:Bench Bandsaw]] | |
 +| [[tool:Horizontal Bandsaws]] | |
 +====== Metal Shop ======
 +See: [[area:welding|Metal Shop]]
 +| Box and Pan Brake | [[tool:Welder|Millermatic 211 MIG Welder]] | Hand Tools | Safety Equipment |
 +| Welding Table | [[tool:PowerTIG250EX|PowerTIG 250EX Welder]] | | Flux |
 +| [[tool:manual_lathe|Metal Lathe]] | [[tool:Bosch 4.5" Angle Grinder]] | | [[tool:fasteners|Nuts, Bolts, Screws, Washers...]] |
 +| [[tool:Bench Grinder]] | [[tool:Cut-Off Saw]] |  | Donated metal |
 | [[tool:Green Manual Mill]] | [[tool:18.0V Cordless Drill]] | | [[tool:Green Manual Mill]] | [[tool:18.0V Cordless Drill]] |
 | [[tool:Bench Bandsaw]] | [[tool:Plasma Cutter]] | | [[tool:Bench Bandsaw]] | [[tool:Plasma Cutter]] |
 | [[tool:Horizontal Bandsaws]] | [[tool:Ring Roller]] | | [[tool:Horizontal Bandsaws]] | [[tool:Ring Roller]] |
-| [[tool:Bench Grinder]] |
 | [[tool:Scroll Saw]] | | [[tool:Scroll Saw]] |
 | [[tool:Buffing Machine]] | | [[tool:Buffing Machine]] |
Line 149: Line 173:
 | [[tool:Blacksmith forge and anvil]] | | [[tool:Blacksmith forge and anvil]] |
 | [[tool:Heat Treating Oven]] | | [[tool:Heat Treating Oven]] |
Line 161: Line 184:
 | [[tool:Drill Press]] | [[tool:Random-Orbit Palm Sander]] | [[tool:wood steamer|Wood Steamer]] | [[tool:fasteners|Nuts, Bolts, Screws, Washers...]] |  | [[tool:Drill Press]] | [[tool:Random-Orbit Palm Sander]] | [[tool:wood steamer|Wood Steamer]] | [[tool:fasteners|Nuts, Bolts, Screws, Washers...]] |
 | [[tool:Bench Bandsaw]] | [[tool:18.0V Cordless Drill]] | [[tool:Norseman Drill Bit Set]] |  | | [[tool:Bench Bandsaw]] | [[tool:18.0V Cordless Drill]] | [[tool:Norseman Drill Bit Set]] |  |
-| [[tool:Scroll Saw]] | [[tool:Jointer]] |  |  |+| [[tool:Scroll Saw]] | [[tool:Jointer]] | [[tool:French Cleat Wall]] |  |
 | [[tool:Table Saw]] | [[tool:Cut-Off Saw]] | | [[tool:Table Saw]] | [[tool:Cut-Off Saw]] |
 | [[tool:Mini Wood (Pen) Lathe]] | [[tool:Planer 40200H]] | | [[tool:Mini Wood (Pen) Lathe]] | [[tool:Planer 40200H]] |
Line 174: Line 197:
 | [[tool:Dremel Vibrating Multi Tool]] |  | | [[tool:Dremel Vibrating Multi Tool]] |  |
-===== Maintenance/Facility =====+====== Maintenance/Facility ======
Line 180: Line 203:
 | [[tool:powertec_air_filter|POWERTEC AF1044 3SPD Air Filtration System]] | | [[tool:powertec_air_filter|POWERTEC AF1044 3SPD Air Filtration System]] |
 | [[tool:transformer|20kVA Transformer]] | | [[tool:transformer|20kVA Transformer]] |
 +| [[tools:Boge Air Compressor|Boge Air Compressor]] |
 ====== Retirement ====== ====== Retirement ======
tool.txt · Last modified: 2024/04/29 05:27 by dbynoe
