tool:horizontal_bandsaws
tool:horizontal_bandsaws [2015/10/17 17:53] – rsim | tool:horizontal_bandsaws [2018/06/23 21:24] – rsim | ||
====== Horizontal Bandsaws ====== | ====== Horizontal Bandsaws ====== | ||
- | VHS has two horizontal bandsaws that are for cutting metal and plastic stock down to usable lengths for machining on the various machine tools such as the lathe and mills. | + | VHS has two horizontal bandsaws that are for cutting metal and plastic stock down to usable lengths for machining on the various machine tools such as the lathe and mills. These are NOT wood bandsaws. |
Line 6: | Line 6: | ||
====== Yellow ====== | ====== Yellow ====== | ||
+ | This bandsaw has a blade installed that is specifically for cutting larger solid aluminium or plastic stock. Do not use this bandsaw for ferrous metals (e.g. steels) nor small (~1/4" [6mm] or less) stock! | ||
^ Status | ^ Status | ||
Line 16: | Line 18: | ||
^ Arrival Date | November 2012 | | ^ Arrival Date | November 2012 | | ||
^ Location | ^ Location | ||
- | ^ Value | $300 | | ||
- | NOTE: This bandsaw has a blade installed that is specifically for cutting larger solid aluminium or plastic stock. No ferrous metals (e.g. steels) or small (~1" or less) stock! | ||
====== Green ====== | ====== Green ====== | ||
+ | This bandsaw has a blade installed that is specifically for cutting smaller stock of non-ferrous metals (e.g. aluminium), ferrous metals (e.g. steels), and plastic stock. Due to the smaller tooth pitch on the blade it is suitable for cutting smaller stock than the other bandsaw. If you are cutting aluminium or plastic stock that is suitable for the other bandsaw, please use it instead as those materials will tend to gum up/damage this bandsaws blade (and it's approximately 4x the price!). | ||
Line 29: | Line 30: | ||
^ Owner | Family friend of John C | | ^ Owner | Family friend of John C | | ||
^ Arrival Date | November 2013| | ^ Arrival Date | November 2013| | ||
- | NOTE: This bandsaw has a blade installed that is specifically for cutting smaller stock of non-ferrous metals (e.g. aluminium), ferrous metals (e.g. steels), and plastic stock. Due to the smaller tooth pitch on the blade it is suitable | + | ===== Replacement Blades ===== |
+ | Both bandsaws use 64 1/2" x 1/2" blades. 14 TPI bi-metal for the yellow | ||
Line 53: | Line 54: | ||
- | * Select the correct bandsaw for your material and its size. If the material/ | + | * Select the correct bandsaw for your material and its size. If the material/ |
* Drag the bandsaw out (don't try to tilt it up to get it to roll on its wheels, it's VERY dangerous and hard. They seriously slide much better than they roll). | * Drag the bandsaw out (don't try to tilt it up to get it to roll on its wheels, it's VERY dangerous and hard. They seriously slide much better than they roll). | ||
* Clear the area of any obstructions. | * Clear the area of any obstructions. | ||
Line 79: | Line 80: | ||
| Wiki entry updated | Oct 17, 2015 | Richard S. | | | Wiki entry updated | Oct 17, 2015 | Richard S. | | ||
+ | ===== Resources ==== | ||
+ | * http:// |
tool/horizontal_bandsaws.txt · Last modified: 2018/06/24 04:42 by rsim
