vhs_member_initiation
vhs_member_initiation [2019/04/08 03:25] – 00739 | vhs_member_initiation [2019/04/20 22:25] (current) – 00739 | ||
- | ===== How Hackspaces Work (and VHS In Particular) ===== | + | ====== How Hackspaces Work (and VHS In Particular) |
- | ==== Entirely | + | ===== We are entirely |
* Your membership dues are a donation that keep us alive! | * Your membership dues are a donation that keep us alive! | ||
Line 10: | Line 10: | ||
- | ==== Do-ocracy ==== | + | ===== Do-ocracy |
VHS is, first and foremost, a " | VHS is, first and foremost, a " | ||
Line 18: | Line 18: | ||
- | * Bathrooms | + | |
* The phone | * The phone | ||
- | * The [[admin:codes_of_conduct|Code of Conduct]] | + | * The [[admin:code_of_conduct|Code of Conduct]] |
Line 36: | Line 35: | ||
- | ==== Know the different roles at VHS: ==== | + | ===== Know the different roles at VHS: ===== |
Line 64: | Line 63: | ||
vhs_member_initiation.1554693914.txt.gz · Last modified: 2019/04/08 03:25 by 00739
