vhs_member_initiation
vhs_member_initiation [2019/03/16 17:28] – 00739 | vhs_member_initiation [2019/04/20 22:25] (current) – 00739 | ||
- | ===== How Hackspaces Work (and VHS In Particular) ===== | + | ====== How Hackspaces Work (and VHS In Particular) |
- | ==== Entirely | + | ===== We are entirely |
* Your membership dues are a donation that keep us alive! | * Your membership dues are a donation that keep us alive! | ||
Line 10: | Line 10: | ||
- | ==== Do-ocracy ==== | + | ===== Do-ocracy |
- | VHS is, first and foremost, a " | + | VHS is, first and foremost, a "[[admin:do-ocracy]]" |
The system works because everyone helps pick up the slack. This is what makes us awesome! Please introduce yourself to existing members; they want to be your friend! | The system works because everyone helps pick up the slack. This is what makes us awesome! Please introduce yourself to existing members; they want to be your friend! | ||
Line 18: | Line 18: | ||
- | * Bathrooms (and bathroom keys!) | + | |
- | * The phone (for buzzing in members and visitors) | + | * The phone |
- | * The [[codes_of_conduct|Code of Conduct]] | + | * The [[admin: |
Line 36: | Line 35: | ||
- | ==== Know the different roles at VHS:* ==== | + | ===== Know the different roles at VHS: ===== |
Line 64: | Line 63: | ||
vhs_member_initiation.1552757326.txt.gz · Last modified: 2019/03/16 17:28 by 00739
