vhs_member_initiation
vhs_member_initiation [2019/03/14 01:22] – 00739 | vhs_member_initiation [2019/04/20 22:25] (current) – 00739 | ||
- | ===== How Hackspaces Work (and VHS In Particular) ===== | + | ====== How Hackspaces Work (and VHS In Particular) |
- | === Entirely | + | ===== We are entirely |
- | Your membership dues are a donation that keep us alive! | + | * Your membership dues are a donation that keep us alive! |
+ | * The huge majority of it goes to rent, followed by services and some tool upkeep. | ||
+ | * Almost everything you see at VHS has been a donation, or purchased using these funds. | ||
- | The huge majority of it goes to rent, followed by services and some tool upkeep. | ||
- | Almost everything you see at VHS has been a donation, or purchased using these funds. | + | ===== Do-ocracy ===== |
- | + | VHS is, first and foremost, a "[[admin:do-ocracy]]" | |
- | === Do-ocracy === | + | |
- | VHS is, first and foremost, a " | + | |
The system works because everyone helps pick up the slack. This is what makes us awesome! Please introduce yourself to existing members; they want to be your friend! | The system works because everyone helps pick up the slack. This is what makes us awesome! Please introduce yourself to existing members; they want to be your friend! | ||
Line 20: | Line 18: | ||
- | * Bathrooms (and bathroom keys!) | + | |
- | * The phone (for buzzing in members and visitors) | + | * The phone |
- | * The [[codes_of_conduct|Code of Conduct]] | + | * The [[admin: |
Line 38: | Line 35: | ||
- | **Know the different roles at VHS:** | + | ===== Know the different roles at VHS: ===== |
Line 66: | Line 63: | ||
- | ===== Important links ===== | ||
- | * Talk | ||
- | * isvhsopen |
vhs_member_initiation.1552526546.txt.gz · Last modified: 2019/03/14 01:22 by 00739
