vhs_member_initiation
vhs_member_initiation [2018/02/14 04:13] – i-make-robots | vhs_member_initiation [2019/04/20 22:25] (current) – 00739 | ||
- | Welcome, | + | ====== How Hackspaces Work (and VHS In Particular) ====== |
+ | Welcome | ||
+ | ===== We are entirely member-funded ===== | ||
+ | * Your membership dues are a donation that keep us alive! | ||
+ | * The huge majority of it goes to rent, followed by services and some tool upkeep. | ||
+ | * Almost everything | ||
+ | ===== Do-ocracy ===== | ||
+ | VHS is, first and foremost, a " | ||
+ | The system works because everyone helps pick up the slack. This is what makes us awesome! Please introduce yourself to existing members; they want to be your friend! | ||
- | VHS is, first and foremost, a " | ||
- | * Bathrooms (and bathroom keys!) | + | |
- | * The phone (for buzzing in members and visitors) | + | * The phone |
- | * The [[codes_of_conduct|Code of Conduct]] | + | * The [[admin: |
Line 22: | Line 35: | ||
- | **Know the different roles at VHS:** | + | ===== Know the different roles at VHS: ===== |
Line 50: | Line 63: | ||
vhs_member_initiation.1518581637.txt.gz · Last modified: 2018/02/14 04:13 by i-make-robots
