tool:ultrasonic_cleaner
tool:ultrasonic_cleaner [2017/07/24 03:15] – created lbuchy | tool:ultrasonic_cleaner [2021/03/27 17:07] (current) – johnc | ||
====== Ultrasonic Cleaner | ====== Ultrasonic Cleaner | ||
Line 18: | Line 18: | ||
- | * Powerful 300W Ultrasonic Cleaner | + | |
- | * Large 6 Liters (1.58 gallon) stainless steel (SU304) tank | + | * Large 6 Liters (1.58 gallon) stainless steel (SU304) tank |
- | * Tank size: 12.8" x 8.0" x 3.9". The longest item which can fit in is 13.4" | + | * Tank size: 12.8" x 8.0" x 3.9". The longest item which can fit in is 13.4" |
- | * 2 Color LED display. 1-30 minutes full range timer for ultrasonic cleaning | + | * 2 Color LED display. 1-30 minutes full range timer for ultrasonic cleaning |
- | * 5 heating temperature settings from 40 degree C (104F) to 60 degree C (140F) | + | * 5 heating temperature settings from 40 degree C (104F) to 60 degree C (140F) |
===== Examples of things you can clean ===== | ===== Examples of things you can clean ===== | ||
- | * PCBs | + | |
- | * Precision parts (bearings, gears, valves) | + | * Precision parts (bearings, gears, valves) |
- | * Tools | + | * Tools |
- | * Lab items (glassware) | + | * Lab items (glassware) |
- | * Electrical parts | + | * Electrical parts |
- | * Lenses and mirrors | + | * Lenses and mirrors |
- | * Glasses | + | * Glasses |
- | * Bicycle components | + | * Bicycle components |
- | * Automotive parts | + | * Automotive parts |
===== Modes of cleaning ===== | ===== Modes of cleaning ===== | ||
Line 43: | Line 43: | ||
- Add water to the cleaning take to the level between " | - Add water to the cleaning take to the level between " | ||
- Put the items to be cleaned inside the basket and put the basket inside the tank | - Put the items to be cleaned inside the basket and put the basket inside the tank | ||
+ | - Set temperature if needed and wait for liquid to reach set temperature. | ||
- Turn the main switch on. Press TIME button to set the timer to 5-10 minutes. | - Turn the main switch on. Press TIME button to set the timer to 5-10 minutes. | ||
Line 56: | Line 57: | ||
- Put the item inside a container. Add proper fluid to submerge item. | - Put the item inside a container. Add proper fluid to submerge item. | ||
- Place the container in the tank directly. | - Place the container in the tank directly. | ||
+ | - Set temperature if needed, wait for liquid to hit set temperature | ||
- Press TIME button to set the timer to 10 minutes. Press On/Off button to start cleaning. | - Press TIME button to set the timer to 10 minutes. Press On/Off button to start cleaning. | ||
Line 70: | Line 72: | ||
* If cleaning multiple parts simultaneously, | * If cleaning multiple parts simultaneously, | ||
+ | ===== Clean-up and Storage ===== | ||
+ | * Rinse, drain, and wipe the reservoir dry. | ||
+ | * Store the ultrasonic cleaner on a shelf in the paint and mess room. |
tool/ultrasonic_cleaner.1500866159.txt.gz · Last modified: 2017/07/24 03:15 by lbuchy
