tool:redsail_cm1080_laser_cutter [2017/10/05 21:35] jdmctool:redsail_cm1080_laser_cutter [2024/04/16 04:48] (current) – Added stepper driver details ddq
 ====== Redsail CM1080 Laser Cutter ====== ====== Redsail CM1080 Laser Cutter ======
-{{::generic-tool.png?200 |}}+{{:tool:high_speed_co2_acrylic_laser_cutting_machine_cm1080_with_ce_fda.jpg?400|}}
 Everybody loves lasers Everybody loves lasers
-^ Status             WORKING as 2017-03-21  |+^ Status             OPERATIONAL as of April 9, 2024  |
 ^ Training           | YES (see below)                                              | ^ Training           | YES (see below)                                              |
 ^ Hackable           | NO                                              | ^ Hackable           | NO                                              |
Line 15: Line 17:
 ^ Value           | $3500 + ~$1000 to get it here and set up                                                     | ^ Value           | $3500 + ~$1000 to get it here and set up                                                     |
 ^ Champion           | See [[tool:compendium_of_champions|Compendium of Champions]]  | ^ Champion           | See [[tool:compendium_of_champions|Compendium of Champions]]  |
Line 25: Line 28:
   - **Wear the Laser safety glasses at all times.**   - **Wear the Laser safety glasses at all times.**
   - **Operator must remain within 1m of the machine and monitor cutting at all times when the machine is in operation.**   - **Operator must remain within 1m of the machine and monitor cutting at all times when the machine is in operation.**
-  - **Only lase Approved Materials.**  (See [[tool:laser_cutter:materials|Laser Cutter Approved Materials List]])+  - **Only burn Approved Materials.**  (See [[tool:laser_cutter:settings|Laser Cutter Approved Materials List]])
 Failure to follow these rules may result in immediate loss of Laser Cutter priviledges. Failure to follow these rules may result in immediate loss of Laser Cutter priviledges.
Line 39: Line 42:
   * Type: CO2   * Type: CO2
   * Power: 80W   * Power: 80W
-  * Controller: [[http://www.lightobject.com/2012-Commercial-DSP-CO2-Laser-Engraving-Cutter-Controller-Support-CorelDraw-AutoCad-P321.aspx|AWC-608B]] (replacement for original, installed 2013+  * Controller: [[https://lightobject.com/r6-dsp-controller-card-for-co2-laser-machine/|Ruida 6445]] (replacement [[https://talk.vanhack.ca/t/new-laser-controller/14625/3|installed in 2023]]
-  * Chiller: [[http://vanhack.ca/doku.php?id=tool:laser_cutter:chiller|AC unit water chiller]]+  * Chiller: [[https://lightobject.com/q800-water-chiller/|LightObject Industrial Water Chiller Q800]], [[https://talk.vanhack.ca/t/new-laser-tube-and-water-chiller-installed-july-2022/13367|installed July 2022]]
   * Power supply: [[http://www.lightobject.com/80W100W-PWM-CO2-Laser-Power-Supply-AC220V-P73.aspx|LSR-JN80WCO2-2V]]   * Power supply: [[http://www.lightobject.com/80W100W-PWM-CO2-Laser-Power-Supply-AC220V-P73.aspx|LSR-JN80WCO2-2V]]
     * Input: AC 220V     * Input: AC 220V
Line 49: Line 52:
     * 3pin terminal pinout: G, AC, AC     * 3pin terminal pinout: G, AC, AC
     * 6pin terminal pinout: H, L, WP, G, IN, 5V     * 6pin terminal pinout: H, L, WP, G, IN, 5V
 +  * 3-Phase Stepper Motor Drivers: [[https://www.amazon.ca/dp/B07DQPCRRN|Cloudray 3DM580S]] or Moons 3SR8H
 +    * Note: Different driver models have different pinouts even though the connectors are the same. DO NOT swap connectors without changing the wire order.
 +    * Input: DC 40V
 +    * Motor current: 4A
 +    * Steps/rev: 5000
 +    * Idle current: half
 +    * Power-on self test: off
-===== Maintentance Log ===== +===== Usage and Maintenance =====
-  * [[tool:laser_cutter:maintenance|Maintenance Logs]]+  * [[tool:laser_cutter:settings|Laser Cutter Approved Materials List]]
 +  * [[tool:laserfilter|Filters and Filter Maintenance]]
 +  * [[tool:laserfilter#list_of_Past_Maintenance_Logs|Maintenance Logs]]
 ===== Further Information ===== ===== Further Information =====
Line 57: Line 69:
   * [[tool:laser_cutter:training|VHS Laser Cutter Training]]   * [[tool:laser_cutter:training|VHS Laser Cutter Training]]
   * [[tool:laser_cutter:operation_manual|Laser Cutter Operation Manual]]   * [[tool:laser_cutter:operation_manual|Laser Cutter Operation Manual]]
-  * [[tool:laser_cutter:settings|Laser Cutter Approved Materials List]]+  * [[https://www.bosslaser.com/Download_pdf/LaserCAD_manual.pdf LaserCAD Manual]]
   * [[tool:laser_cutter:MSDS|How do I get a new material approved?]]   * [[tool:laser_cutter:MSDS|How do I get a new material approved?]]
   * [[tool:laser_cutter:workflow_tips|Laser Cutter Workflow Tips]]   * [[tool:laser_cutter:workflow_tips|Laser Cutter Workflow Tips]]
   * [[tool:laser_cutter:parts|Laser Cutter Components]]   * [[tool:laser_cutter:parts|Laser Cutter Components]]
 +  * [[tool:laser_cutter:laser_focus_lens_focal_length|Laser focus lens focal length]]
tool/redsail_cm1080_laser_cutter.1507239325.txt.gz · Last modified: 2017/10/05 21:35 by jdmc
