tool:powertec_air_filter
Name of Tool
Status Operational as of Mar 12, 2019
Training Optional
If it Breaks (Panic procedure, usually involving emailing list and “broken” sign)
Loan Status Owned
Arrival Date April 2016
Location Woodshop
Value $300
https://www.amazon.ca/gp/product/B012MI1G3W/ref=ppx_od_dt_b_asin_title_s00?ie=UTF8&psc=1
http://powertecproducts.com/af1044-3spd-air-filtration-system-556-702-1044-cfm/
af1044manual.pdf
Horsepower (Maximum Developed): .1/5 HP, 120 V, 60 Hz 3 Speeds, Motor Amperage: 3A/ 2-1/2A / 2A; Motor Speeds: 750/960/1200 RPM, Air Flow: 556/702/1044-CFM, Outer Filter: 5 Micron, Inner Filter: 1 Micron, Filtration Timing: 1HR, 2HR, 4HR, Gross Weight: 73 lbs, Sound Rating @ 3 Feet: High Speed : 69dB, Medium Speed 67dB, Low Speed 62 dB
. Powerful, quiet, efficient, and potent air filtration system
. Easy to replace filter; no tools required; Outer filter: 5 micron; Inner filter: 1 micron
. 3 Air flows: 556/702/1044-CFM
. Infrared remote control system; 3 timer setting: 1hr/2hr/4hr
. Includes remote control and mounting hardware
Replacement filters:
http://powertecproducts.com/content/AF1044Manual.pdf
Wiki entry created Mar 12, 2019 Thomas L.
tool/powertec_air_filter.txt · Last modified: 2019/03/12 18:22 by laftho
