tool:laser_cutter:settings
tool:laser_cutter:settings [2019/05/30 21:59] – jdmc | tool:laser_cutter:settings [2019/10/17 04:49] – Increased speed for 1/8 ply from 16 to 24 tristan_lane | ||
Line 17: | Line 17: | ||
| Plywood 1/4" Birch | Cut | 40 | 50 | 45 | 2 | From Home Depot ~$50 for 8' | | Plywood 1/4" Birch | Cut | 40 | 50 | 45 | 2 | From Home Depot ~$50 for 8' | ||
- | | Plywood 1/8" Birch | Cut | | + | | Plywood 1/8" Birch | Cut | |
- | | Plywood 1/8" Maple| Cut | | + | | Plywood 1/8" Maple| Cut | |
| Plywood 1/8" Birch | Etch | 80 | 28 | 28 | 1 | Deep etching, excellent for countersinking screw holes | | | Plywood 1/8" Birch | Etch | 80 | 28 | 28 | 1 | Deep etching, excellent for countersinking screw holes | | ||
| Plywood 4.2mm FSC Virola | Cut | 40 | 50 | 45 | 2 | From Home Depot ~$20 for 8' | | Plywood 4.2mm FSC Virola | Cut | 40 | 50 | 45 | 2 | From Home Depot ~$20 for 8' | ||
Line 67: | Line 67: | ||
| Fiberglass | Hazardous dust | | | Fiberglass | Hazardous dust | | ||
| Printed Circuit board | Hazardous dust | | | Printed Circuit board | Hazardous dust | | ||
+ | ====== Provisionally Approved ====== | ||
+ | The following materials have been provisionally approved by the Laser Cutter Committee for testing: | ||
+ | ^ Material ^ Mode ^ Speed ^ Power ^ Corner Power ^ Passes ^ Notes ^ | ||
+ | | Cork | Cut | TBD | TBD | TBD | TBD | | ||
+ | | Cork | Etch | TBD | TBD | TBD | TBD | | ||
====== FURTHER INFORMATION ====== | ====== FURTHER INFORMATION ====== |
tool/laser_cutter/settings.txt · Last modified: 2022/09/27 01:05 by david_neufeld
