tool:laser_cutter:settings
Both sides previous revisionPrevious revision | Next revisionBoth sides next revision | ||
tool:laser_cutter:settings [2018/09/19 01:45] – jdmc | tool:laser_cutter:settings [2019/05/30 21:59] – jdmc | ||
Line 18: | Line 18: | ||
| Plywood 1/4" Birch | Cut | 40 | 50 | 45 | 2 | From Home Depot ~$50 for 8' | | Plywood 1/4" Birch | Cut | 40 | 50 | 45 | 2 | From Home Depot ~$50 for 8' | ||
| Plywood 1/8" Birch | Cut | 16 | 55 | 55 | 1 | From Windsor Plywood ~$17 for 5' | | Plywood 1/8" Birch | Cut | 16 | 55 | 55 | 1 | From Windsor Plywood ~$17 for 5' | ||
+ | | Plywood 1/8" Maple| Cut | 16 | 55 | 55 | 1 | | | ||
| Plywood 1/8" Birch | Etch | 80 | 28 | 28 | 1 | Deep etching, excellent for countersinking screw holes | | | Plywood 1/8" Birch | Etch | 80 | 28 | 28 | 1 | Deep etching, excellent for countersinking screw holes | | ||
| Plywood 4.2mm FSC Virola | Cut | 40 | 50 | 45 | 2 | From Home Depot ~$20 for 8' | | Plywood 4.2mm FSC Virola | Cut | 40 | 50 | 45 | 2 | From Home Depot ~$20 for 8' | ||
- | | Plywood 1/4" Flooring underlay | Cut | 12 | 60 | 60 | 1 | From Home Depot ~$9 for 4' | + | | Plywood 1/4" Flooring underlay | Cut | 12 | 60 | 60 | 1 | From Home Depot ~$9 for 4' |
Line 37: | Line 38: | ||
===== Fabric ===== | ===== Fabric ===== | ||
- | | Leather | Cut | | | | 1 | Leather from Dressew scrap bin (Paul) | + | | Leather |
| Felt | Cut | | | | | | | | Felt | Cut | | | | | | | ||
===== Other ===== | ===== Other ===== | ||
+ | | Application Tape | | | | | | Small amounts used for masking | | ||
+ | | Painters Tape | | | | | | Small amounts used for masking | | ||
===== Etch Only ===== | ===== Etch Only ===== |
tool/laser_cutter/settings.txt · Last modified: 2022/09/27 01:05 by david_neufeld
