Both sides previous revision Previous revision
tool:laser_cutter:operation_manual [2018/01/12 07:38]
jdmc
tool:laser_cutter:operation_manual [2019/07/31 19:37] (current)
chad.leaman_gmail.com
Line 157: Line 157:
 ===== System Power-up ===== ===== System Power-up =====
 The Laser Access System will automatically turn on the Fume Extraction System, the Chiller, the Air Compressor, and the Laser Cutter. If the HVAC system in the space is currently running, the fan will be shut off.  The Laser Access System will automatically turn on the Fume Extraction System, the Chiller, the Air Compressor, and the Laser Cutter. If the HVAC system in the space is currently running, the fan will be shut off.
 +If the system is off, the power for the laser cutter is over by the fridge in the lounge area
 Be aware that when the Laser Cutter is first powered, the head and gantry will move to the home position automatically. Be aware that when the Laser Cutter is first powered, the head and gantry will move to the home position automatically.
tool/laser_cutter/operation_manual.txt · Last modified: 2019/07/31 19:37 by chad.leaman_gmail.com
