tool:green_manual_mill
tool:green_manual_mill [2014/01/30 07:18] davidcarnetool:green_manual_mill [2023/02/09 20:43] (current) – Corrected spindle taper to Morse MT3 androidlx
 ====== Manual Mill ====== ====== Manual Mill ======
-{{::green-manual-mill.jpg?200 |}} +^ Status             | Operational as of February 2021
- +^ Training           Required                                       |
-Summary description of the tool and perhaps some misc notes about it's existence! +
-^ Status             | Operational as of November 2013                           +
-^ Training           Recommended                                       |+
 ^ Hackable           | NO                                                              | ^ Hackable           | NO                                                              |
-^ Usage Restrictions | Members Only                     | +^ Usage Restrictions | Members Only, only after VHS training / orientation                     |
-^ Owner              | (VHS or Name of proper owner)                                          | +^ Owner              | Mark Denny (friend of JohnC)                                          |
-^ If it Breaks       (Panic procedure, usually involving emailing list and "broken" sign  | +^ If it Breaks       Attach "Out of Order" sign / note. Post to Talk and Slack, contact area Champions   |
-^ Loan Status        | Temporary                  |+^ Loan Status        | Long Term Loan                 |
 ^ Arrival Date       | November 2013        | ^ Arrival Date       | November 2013        |
-^ Location           (Location within VHS, eg Workshop                                      +^ Location           Machine Shop                                      |
-^ Value              | $$        |+
 +{{ ::green-manual-mill.jpg?200| }}
 ===== Safety ===== ===== Safety =====
-** THERE IS NO BELT GUARD FOR THE TOP OF THE MILL. ONE NEEDS TO BE FABRICATED ** +Always wear eye protection while using the mill. VHS-specific training / orientation is required. If used improperlyworkpieces or pieces of cutting tools can be thrown around the shop at high velocity.
-Always wear eye protection while using the mill. Do not use the mill if you do not know how to use this type of machine. If used improperlyworkpieces of pieces of cutting tools can be thrown around the shop at high velocity.+
 ===== Specifications: Mill ===== ===== Specifications: Mill =====
-Mill is a Long Chang LC-15A. No specifications for this mill appear to be available online. The following information was measured from the mill and may be inaccurate.+Mill is a Long Chang LC-15A. Very little info for this mill is available online.
 +Please review this {{ :tool:lc15_lc30_manual.pdf | Basic Manual }}
-Spindle Taper: Measured ~3.215in long, 0.8in minor diameter, 0.95in major diameter. Very close to Morse #3+The following information was measured from the mill and may be inaccurate.
 +Spindle Taper: MT3 - Morse Taper #3
 Table: 1/2in T slots Table: 1/2in T slots
Line 32: Line 31:
 ===== Notes ===== ===== Notes =====
-To move mill head up and down (major vertical adjustment); you need to loosen two bolts on the right-hand-side of the head, and use the crank on the left-hand-side of the mill to raise or lower. Retighten securing bolts before use (when untightened, crank has huge slop).+To move mill head up and down (major vertical adjustment); you need to loosen two nuts on the right-hand-side of the head, and use the crank on the left-hand-side of the mill to raise or lower. Retighten securing bolts before use (when loose, crank has huge slop).
 ===== Axes ===== ===== Axes =====
 X/Y - handwheels on table X/Y - handwheels on table
 Z - large grab handle on right of mill, or handwheel on front of mill. Black locking ring on grab-handle on right of mill engages/disengages handwheel. This axis can be locked via the small black lever on the front-left of the mill head. Z - large grab handle on right of mill, or handwheel on front of mill. Black locking ring on grab-handle on right of mill engages/disengages handwheel. This axis can be locked via the small black lever on the front-left of the mill head.
-===== Tooling =====+===== Fixtures =====
-- 1/4, 3/8, 1/2in collets +The 3.5" swivel vise can be bolted to the table via T nuts bolts. Never assume that the vise is aligned correctly; use a dial indicator to check.
-- Drill Chuck +
-- (many more)+We have a set of 1/2in T nuts + fingers + step blocks for the CNC mill that will also fit this mill.
 +===== Tooling =====
 +- Drill Chuck - at the moment, the only chuck key that fits is on the drill press in the Fab shop area.
 +- 2x Offset boring heads
 +- Fly cutter. Takes an HSS toolbit, ground to the correct profile
 +- 1/4, 3/8 and 1/2 collets. Used to hold end mills, fly cutters, and the small boring head
 +- 2.5" face mill. Needs to be replaced, as all the carbides are chipped, and are not available for purchase. Still works reasonably well
 +- Drift keys. USe to remove the tooling from the spindle. See document (pending) for use.
 +- (many more in varying condition)
 +- (Most) tooling is located in the red toolbox in the end of the (pending) work bench.
 +===== Speeds & Feeds =====
 +Cutting speeds can be determined easily by using this {{:tool:cutting-speed-nomogram.png?linkonly|cutting speed nomogram}}. The {{:tool:lathe-cutting-speed.png?linkonly|original cutting speed nomogram}} came from Ian at the BCSME.
 ===== Tutorial ===== ===== Tutorial =====
-A written tutorial won't suffice! Don't touch the machine unless you've received training or used similar equipment!+A written tutorial won't suffice! Don't touch the machine unless you've received training!
 ===== Maintenance Log ==== ===== Maintenance Log ====
Line 53: Line 67:
 ^ Note               ^ Date         ^ Who       ^ ^ Note               ^ Date         ^ Who       ^
 | Wiki entry created | Nov 20, 2013 | Thomas L. | | Wiki entry created | Nov 20, 2013 | Thomas L. |
 +| Wiki entry updated | Nov 27, 2013 | QuanaParker |
 +| Vice alined and bolted to table | Nov 26, 2013 | QuanaParker |
 +| Tool/Work bench built  {{::tool:grizzly_toolbench_img_3981.jpg?200}} {{::tool:grizzly_toolbench_img_3983.jpg?200}} | Nov 26, 2013 | QuanaParker |
 +| New drawbar, drift keys | Feb 2020 | Billiam |
tool/green_manual_mill.1391066313.txt.gz · Last modified: 2015/12/12 14:31 (external edit)
